Re: two point drawbars
Posted by Hugh MacKay on January 17, 2002 at 16:13:11 from (142.177.113.13):
In Reply to: two point drawbars posted by Don Shepard on January 16, 2002 at 22:33:36:
Don: I will try this again, I tried this am and pushed the wrong button and lost my text. Two sizes of forks Small Super C, 200, 230 and 240, Large on all the larger tractors. There are 3 different chassis widths, small again same as above; medium 300, 330, 340, 350 and 460; large 400, 450, 560, etc. Also if the hitch is new enough it will have draft control. Your 340 may or may not have draft control in one of its valves. If not you should get the valve off the tractor the hitch came from. May be hard to find later.
Post A Followup
: Re: Re: two point drawbars
