Re: Re: compression for H
Posted by Paul Shuler on January 17, 2002 at 18:01:26 from (12.28.56.82):
In Reply to: Re: compression for H posted by The Red on January 16, 2002 at 13:12:01:
Hi Red. Would this also be true for a Super C as far as compression goes? I have a post about it on this same page. When I tried to check mine I got approx 50psi. The old tractor runs good but that seemed a little low to me. I used an old gauge with a rubber stopper that you press into the sparkplug hole while I had someone turn the hand crank. Is there a more reliable way to test this before I tear into the motor and may not need to.
Thanks in advance Red,
Paul
Post A Followup
: Re: Re: Re: compression for H
