Re: removing gas tank on a H
Posted by Larry on January 17, 2002 at 20:46:57 from (216.202.132.34):
In Reply to: removing gas tank on a H posted by Olaf on January 17, 2002 at 20:11:53:
Try soaking bolts with PB Blaster or Liquid Wrench..let it sit awhile and keep it soaked. Ya got me on the 'white stuff'..usually the problem is rust. Depending on the nature of the contamination in the tank (rust, dirt, white stuff) you may not need to do anything more than clean it out good with kero or parts cleaner. Rust may require mechanical removal (chain, nuts, bolts, shot, etc. in tank and agitate) and then possibly sealing tank with product like Kreem. Curious what that white material might be! Good luck
Post A Followup
: Re: Re: removing gas tank on a H
