Re: Replacing an engine deck.
Posted by F14...Do you perhaps mean on January 18, 2002 at 05:00:04 from (216.204.134.126):
In Reply to: Replacing an engine deck. posted by lpc on January 17, 2002 at 22:56:17:
the block, with cracks at the top of the cylinder casting where the head bolts on? This is sometimes referred to as the piston deck.
Cracked blocks can sometimes be repaired, but your's sounds pretty bad. Might be better off to go looking for a replacement block. They're fairly commonly available used, in good enough condition where a fresh set of sleeves will put you in business.
Post A Followup
: Re: Re: Replacing an engine deck.
