Re: Sticky Valve(s) on 1944 A
Posted by Steven@nd on January 18, 2002 at 08:12:54 from (165.234.131.176):
In Reply to: Sticky Valve(s) on 1944 A posted by EZHangin on January 17, 2002 at 20:09:30:
This could also be a fuel problem where some junk gets into the line and restricts the flow. The carb might have enough fuel to run for a while in the fuel bowl, but when speeded up it starves.
I doubt your valves are sticking, usually if they stick they do it all the time, not just when warm. If you do decide to spray something on them I wouldn't worry about what gets into the cylinder, the amount will be so small it won't matter.
Check your coil as suggested, they have hot problems sometimes too.
Steven
Post A Followup
: Re: Re: Sticky Valve(s) on 1944 A
