Re: M carb problem
Posted by The Red on January 18, 2002 at 08:51:52 from (206.246.187.2):
In Reply to: M carb problem posted by Jack on January 18, 2002 at 06:42:26:
Jack the idle screw works exactly opposite of the high speed screw. When you turn it counterclockwise, you are adding more air to the mix. I had a carburetor on an H I no longer owned that always ran a wee bit too lean even though I had the idle screw all the way in.
Post A Followup
: Re: Re: M carb problem
