Re: Re: Re: Re: Re: Re: Re: Spark Plugs 6 V verses 12V
Posted by Bob M on January 18, 2002 at 10:22:06 from (165.170.128.66):
In Reply to: Re: Re: Re: Re: Re: Re: Spark Plugs 6 V verses 12V posted by Bob/Maine on January 18, 2002 at 08:43:56:
Bob - Plugs see the same voltage and current regardless of the coil primary voltage. So while a 6 volt coil draws twice the primary current of a 12 V, the output current/voltage of both coils is the same. Hence plug life is independent of coil voltage. Regarding advantages of 12 V has over 6 V is 12 V, the only advantage 12 V has is it lets you use a 6 volt coil with a ballast resistor. Then by arranging the starter switch so it bypasses the resistor while the engine is cranking, you develop an extra hot spark, just when it's needed most (since you are now feeding the 6 V coil 9 or 10 volts during the cranking cycle). This offers no advantage to a low compression tractor motor. However the ballast resistor setup was necessary to insure reliable starting of the high compression automobiles of the late 50's/early 60's. These motors required a lot of battery power to crank, and also needed an extra hot spark to fire the highly compressed fuel/air mixture.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
