Re: Re: Re: 140 rockshaft arm?
Posted by scotty on January 19, 2002 at 03:51:46 from (199.231.49.128):
In Reply to: Re: Re: 140 rockshaft arm? posted by Hugh MacKay on January 18, 2002 at 15:07:23:
Hugh,
Thanks for the info on the 140 Hugh.They obviously made them stronger on later tractors. Haas made a good point on the job that spring does also. My spring needs to be replaced on my 49 Super.Looks like we are finally going to get some real snow in Connecticut, so I can try my plow out on my 42! Have a good weekend.
scotty
Post A Followup
: Re: Re: Re: Re: 140 rockshaft arm?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
