Re: Putting power steering on a 300
Posted by AL on January 19, 2002 at 18:08:54 from (12.84.124.30):
In Reply to: Putting power steering on a 300 posted by Gibby on January 18, 2002 at 22:05:47:
Gibby, if you are going to install a factory Behlen PS unit from a 400 to a 300, I believe you need to change the regulator on the hydra-touch unit to one with the flow-divider valve. The regulator is on the left side of the hydra-touch unit. You might need to get the PS regulator from the 400 as they would be the same for a 300. The high pressure hose from the Behlen unit connects to a port on the the flow divider regulator. The return line from the PS unit then goes into the drain plug on the hydraulic resorver. Hope this helps.
Post A Followup
: Re: Re: Putting power steering on a 300
