Re: I Am Still Confused About 12 Volt Generator Conversion
Posted by Bob M on January 20, 2002 at 18:38:27 from (66.66.72.246):
In Reply to: I Am Still Confused About 12 Volt Generator Conversion posted by cheg on January 20, 2002 at 16:22:52:
You can stick a 12 volt regulator on a 6 volt generator and get 12 volts. This is because a generator acts as a "current source" (not a "voltage source"), and is capable of delivering current at a terminal voltage of 20 - 25 volts or so. However a 6 volt generator running on 12 volts will tend to run hot under full-field (i.e. heavy load) conditions. This is because 12 volts doubles the design current flowing in the field windings, which in turn QUADRUPLES the heat dissipated in windings (P = I^2 * R). Bottom line is a 6 volt generator will work on 12 volts, but depending on the application may not last for long. A true conversion of a generator from 6 to 12 volts involves rewinding the field coils with smaller, higher resistance wire to keep the field current (hence heat dissipation) within design limits. Regarding alternators that will fit under the hood of a "M", there's room up there for most any standard automotive alternator. Only certain older, "high output" (usually 70 amps and above) units, and the older Chrysler externally finned alternators are too big to fit.
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
