Re: 6 or 12 volt tractors
Posted by Red Dave on January 21, 2002 at 11:42:05 from (208.165.46.34):
In Reply to: 6 or 12 volt tractors posted by Gary Alexander on January 21, 2002 at 11:22:12:
The only way I know of is to look at the regulator, sometimes they are marked or maybe you can cross reference the reg part number. Taking a light apart and checking the numbers on the bulb may tell you somthing about the voltage too.
If it has an alternator, instead of a generator it's almost always 12volts, negative ground.
Post A Followup
: Re: Re: 6 or 12 volt tractors
