Re: Farmall 450 gas Electrical problem
Posted by Bob M on January 21, 2002 at 12:24:51 from (165.170.128.66):
In Reply to: Farmall 450 gas Electrical problem posted by Gary Alexander on January 21, 2002 at 11:18:40:
Gary - If the tractor has been converted to an alternator, you are virtually assured it will be negative ground. If it still has a generator, mount the battery and connect both cables - it doesn't matter yet which post is grounded. Now turn on the lights or the ignition (but DON'T start the engine!) and check the ammeter. If it indicates discharge, the battery is installed correctly. If it indicates charge, you guessed wrong on the polarity - simply swap the two battery cables and you're be good to go.
Post A Followup
: Re: Re: Farmall 450 gas Electrical problem
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
