Re: farmall c oil pressure
Posted by Haas on January 21, 2002 at 13:49:53 from (129.37.117.106):
In Reply to: farmall c oil pressure posted by mark on January 21, 2002 at 13:33:18:
Your oil pressure is fine. Anything up to 60 psi is normal. There is a pressure relief on the oil pump that is supposed to open between 50 and 60 psi. If your pressure runs less than 40 or so at full throttle, then something is getting worn or there could be a problem with the pump.
Post A Followup
: Re: Re: farmall c oil pressure
