Re: Alternator putting out 15.25 volts...
Posted by Bob M on January 22, 2002 at 05:04:47 from (165.170.128.65):
In Reply to: Alternator putting out 15.25 volts... posted by Wendel on January 21, 2002 at 19:51:47:
Wendel - 15.25 volts is a bit high. However if you made the reading with the ambient temperature in the teens or below, 15.25 volts is probably OK. (Alternator voltage INCREASES at lower temperatures...)
A couple other things to check:
1 - Are you certain the alternator #2 (voltage sensing) terminal connection is properly made? If #2 is not connected, output voltage will run high.
2 - What does the ammeter indicate after the motor has run a while? If the reading tapers down to 3 or 4 amps with the battery voltage at 15.25, there is no problem.
Post A Followup
: Re: Re: Alternator putting out 15.25 volts...
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
