Re: 1943 Farmall Cub shift lever
Posted by Chad Penny on January 22, 2002 at 09:14:25 from (152.72.169.228):
In Reply to: 1943 Farmall Cub shift lever posted by Troy Hilton on January 22, 2002 at 09:08:33:
there is a couple of them on ebay going for some cheap prices. go to ebay.com and type farmall cub
you will see them there.
you can also use a grear shift off a cub cadet lawn tractor. it doesn't look right but it bolts right up.
Chad
Post A Followup
: Re: Re: 1943 Farmall Cub shift lever
