Re: 1943 Farmall Cub shift lever
Posted by George Willer on January 22, 2002 at 09:29:21 from (64.254.131.73):
In Reply to: 1943 Farmall Cub shift lever posted by Troy Hilton on January 22, 2002 at 09:08:33:
Troy,
Others will point out that the first Cub was built in 1947, so I won't. :-)
If the shifter is in otherwise good condition, it will be easier to repair it than to find another. I have repaired several, by cutting it off below the hole where they usually break, and OA welding another 1/2" rod in its place. Then drill a new hole for the pin that holds it all together. The welding must be done with the shifter dis-assembled...not a difficult job.
I think they shift nicer if the new rod is made longer by a couple inches.
George Willer
Post A Followup
: Re: Re: 1943 Farmall Cub shift lever
