Re: adjusting brakes on a H
Posted by Michael Soldan on January 23, 2002 at 17:08:22 from (216.46.130.80):
In Reply to: adjusting brakes on a H posted by Olaf on January 23, 2002 at 16:44:24:
Olaf, start with the set screws on the bottom fo the brake pans(covers). These screws should be turned in against the brake lining( they won't go all the way in just snug) Next your adjustment is in the clevis at the bottom of each brake pedal. Remove the split pin(cotter) from the pin at the bottom and remove the pin. Turn the clevis adjusting it shorter(I've had to heat one red hot and dunk it in cold water to get it to break free and turn) but with luck it will turn.Adjust and hook back up at the bottom and try the pedal for brake. It's important to get both pedals set equally so you don't have pull left or right when you put on the brake. The clevis is fundamentally the adjustment of the brake. If you can't get good brake you may need to remove the covers( you don't have to take the brake arms off the covers just remove the bolts around the pan and the whole kit and caboodle should pry off) and check the condition of your lining. Also if there is oil on the brake parts you need to put new brake seals in..another story That I would be glad to tell you about if need be. Hopefully you just need to adjust ...good luck from Mike in exeter Ontario...keep us informed
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
