Re: Farmall sleeves
Posted by redbarron on January 24, 2002 at 21:20:23 from (209.195.141.234):
In Reply to: Farmall sleeves posted by Mike on January 24, 2002 at 20:04:14:
Hi Mike
They, are wet sleeves in the 123 Engine not dry.
make sure the groove for the rubber seal in the
block is very clean. Use soapy water or good
lubricant of some kind on the sleeve so, you don't
pinch the seal. Hope this helps, as I have used
this procedure many times with,no problems with
leakes. Luck with your project
RB
Post A Followup
: Re: Re: Farmall sleeves
