Re: Farmall sleeves
Posted by erkel3 on January 25, 2002 at 04:46:18 from (208.193.163.89):
In Reply to: Farmall sleeves posted by Mike on January 24, 2002 at 20:04:14:
Mike, make sure you have the right sleeves as I bought some from an aftermarket outfit and they had too small of an outside diameter and the seals leaked. The only way I was able to fix the problem was buy four new ones from the dealer. Just make sure you're getting the right ones. They should take a lot of hand pressure to get in if not some tapping with hammer and block.
Post A Followup
: Re: Re: Farmall sleeves
