Farmall Tractors Discussion Board
Re: Clutch on IH 364
Posted by Iron man on March 18, 1999 at 17:08:04:
In Reply to: Clutch on IH 364 posted by Donna on March 18, 1999 at 11:36:01:
Could be a couple of things 1st has the tractor ben sitting long if so the disc could be froze to the flywheel or pressure plate 2nd if the pedal is lighter than usual then you may have broken fingers on the pressure plate either case you will likley have to get in to repair this
Post a Followup
: Re: Re: Clutch on IH 364
