Farmall Tractors Discussion Board
Re: Stuck Sleeve with PIX on 51 H
Posted by Miles on March 19, 1999 at 03:35:20:
In Reply to: Stuck Sleeve with PIX on 51 H posted by The Red, John Fritz on March 19, 1999 at 02:54:46:
Weld 3 or 4 vertical beads on the inside walls and after cooling they should come right on out
Post a Followup
: Re: Re: Stuck Sleeve with PIX on 51 H
