FIrst thing I'll caution is that having the tranny on your left, it's often hard to narrow down new noises in an A or B. The noise could be coming from either side and only using the tranny as an amplifier.
You have the two bearings that carry the actual axles at the lower end of either final drive. At teh to end of each, you have a bearing at the outer end, in the drive housing, and another mounted in a cage in the side of the tranny/diff.
That doesn't rule out a failure in the bearings carrying the diff or the tranny shafts, all of which, I believe are simple ball bearings.
The noise could be coming from a lot of places. Jsut for intially tracking it down, I'd suggest that you don't rule out the right side.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
