Farmall Tractors Discussion Board
Re: Stuck Sleeve with PIX on 51 H
Posted by Dumb Idea on March 19, 1999 at 09:13:51:
In Reply to: Stuck Sleeve with PIX on 51 H posted by The Red, John Fritz on March 19, 1999 at 02:54:46:
Red, If you take an 18in. fine tooth hacksaw Blade and try to cut through the sleeve. I have done this on bushings but not on sleeves. If it doesn't work it will keep you occupied for a while.
Post a Followup
: Re: Re: Stuck Sleeve with PIX on 51 H
