Farmall Tractors Discussion Board
Re: Stuck Sleeve with PIX on 51 H
Posted by Tom R on March 19, 1999 at 12:05:03:
In Reply to: Stuck Sleeve with PIX on 51 H posted by The Red, John Fritz on March 19, 1999 at 02:54:46:
Red:
Put that hydraulic jack under the center bolt of the sleeve puller and jack it up until a great deal of the tractors weight is being supported by the sleeve, pour a can of Coke between the sleeve and block and then wait a little bit, it has worked for me.
Hope it works for you Tom R.
Post a Followup
: Re: Re: Stuck Sleeve with PIX on 51 H
