Farmall Tractors Discussion Board
Re: creeper gear
Posted by Farmall Gray on March 19, 1999 at 16:32:50:
In Reply to: creeper gear posted by lumber4 on March 19, 1999 at 11:37:46:
No. The cub cadet has a gear reduction in front
of the transmission, while on the cub there is a
clutch shaft that goes from the clutch in to the
transmission and is the upper shaft that the gears slide on. The rear pto will interchange though.
Post a Followup
: Re: Re: creeper gear
