Re: 1066 charging problem
Posted by Icuby on March 08, 2009 at 11:57:59 from (71.7.10.206):
In Reply to: 1066 charging problem posted by Randy2 on March 08, 2009 at 11:15:51:
The one broken prong is likely to be from the internal reg. Pull the alt apart ,install new reg.,problem may be solved.
