Farmall Tractors Discussion Board
Re: M questions
Posted by Fudd on March 20, 1999 at 07:46:46:
In Reply to: M questions posted by Gene on March 20, 1999 at 06:43:28:
As far as I know the 3 pt is a good one. It depends on what you want to use your tractor for if you want live hydraulics. I read you have to be carefull adding a live pump to an M because you can break the cam gear. A great guy to get parts from is Mike at Steel Wheel Ranch, 913-548-7437. Red Power@712-365-4669. He also deals in parts. Your belly pump should work fine unless you have something special in mind.
Post a Followup
: Re: Re: M questions
