Farmall Tractors Discussion Board
Re: Super A - oil pan removel suggestions needed
Posted by ddg on March 20, 1999 at 15:39:20:
In Reply to: Super A - oil pan removel suggestions needed posted by Bob A on March 20, 1999 at 15:05:30:
The pan shouldn't be more than a 10 min job. The flywheel cover casting at the rear of the pan should come off with just 2 bolts I think, with that out of the way you should be able to get to the rear 3 pan bolts. With that done, just go to the Case-IH dealer or maybe NAPA, get a new gasket & put the pan.
Post a Followup
: Re: Re: Super A - oil pan removel suggestions needed
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
