The shims are to adjust end clearance not side clearance of gears to plate. Sounds like you need another light shim. As far as centering gears, just shove body against gears on pressure side. You want it as tight as you can get it and still turn it with a maybe a foot long bar,these are not real precision pumps. If it is really stiff, you just need to be gentle when you engage the clutch on start up, run it in a little at a time, it will free up readily. If all parts were perfect you would want it free on assembly but I am betting there is some grooving on both ends. If you have over about .008 clearance around gears it will probably not pump very well.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
