Re: 300 12v conversion
Posted by Bob M on March 17, 2009 at 04:41:55 from (151.190.254.108):
In Reply to: Re: 300 12v conversion posted by makin,hay on March 16, 2009 at 20:20:27:
If you go with 6 volt generator I'd highly recommend installing a new voltage regulator at the same time. (VR's do age and wear out. It'll be $45 well spent - trust me!)
Any generator can be set up to operate either positive or negative ground. However if you elect to go with a 12 volt generator I STRONGLY suggest you run it negative ground. This is because it lessens the chance of making a cable connection error should you ever need jump start your 300, saving perhaps both your 300 and the jumping vehicle from serious electrical damage.
