Farmall Tractors Discussion Board
Re: Re: Re: replace Steering Wheel
Posted by steve on March 24, 1999 at 08:03:29:
In Reply to: Re: Re: replace Steering Wheel posted by Don on March 23, 1999 at 18:32:02:
Cheap fix - someone on this list once suggested using increasing diameters of fuel hose, split, over the remaining bare metal rim. Trim the hose around the spokes. Paint the spokes before you start.
After you achieve the rim diameter you want, buy a lace-on steering wheel cover (vinyl would likely do better than leather, if left outdoors) and lace it on.
For wheels with bits of rubber left on them, this person suggested removing the wheel, and tossing it in a campfire to burn them off. Some bits could likely be crumbled off with a vise-grip pliers.
Post a Followup
: Re: Re: Re: Re: replace Steering Wheel
