Farmall Tractors Discussion Board
Re: 340 ind d166
Posted by Harold H on March 24, 1999 at 18:00:28:
In Reply to: 340 ind d166 posted by tom on March 23, 1999 at 19:13:58:
Tom,
The 340 was built both as a Farmall 340 and as a International 340 in both gas and diesel. The D166 engine you refer to is basicly four cylinders of the same six cylinder diesel engine series used in the 460, 560, early 706, and others. It has glow plug pre combustion chambers and is 3 11/16 x 3 7/8 with a 19.7 to 1 compression ratio. It is rated at 2000 rpm and was tested in Nebraska test # 775 with 36.25 db hp and 38.93 pto hp.
Harold H
Post a Followup
: Re: Re: 340 ind d166
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
