Re: Farmall A runninrg rough
Posted by TractormanNC on March 17, 2009 at 05:51:22 from (209.42.181.19):
In Reply to: Farmall A runninrg rough posted by doggonetractors on March 16, 2009 at 23:03:50:
Does it run good at full throttle? If so and you have exhausted all the others advice, here's the problem.
An A or SA with a mag and flattop pistons runs a 40 degree impulse coupling which gives full spark advance as soon as it is running. If it was rebuilt with domed pistons this is too much spark advance. Replace your mag impulse coupling with a 20 or 22 deg if you can find it. The best thing to do is get a battery distributor with a 20 or 22 deg shaft and put it on.
BTDT.
