Re: SMTA rear end
Posted by Mike Schwartz on March 07, 2009 at 09:05:25 from (198.68.134.67):
In Reply to: Re: SMTA rear end posted by Harold hubbard on March 07, 2009 at 04:44:03:
I hope that will be the case. I will jack the tractor up and see if I can hear anything. I just redid the brakes and they were not oily, but I did not remove the backing plates. Will the bull pinion or axle feel loose at all or do the housings support them to well to tell if there is a bad bearing? I will dig into it today and report back, thanks, MIke S.
