Posted by Bob Kerr on March 17, 2009 at 07:15:44 from (216.249.67.127):
In Reply to: 10-20 CARB CLEAN posted by DAN DOYLE on March 15, 2009 at 18:40:43:
A 24 10-20 was made to run kerosene. It will run on gas, but may sputter and lose power if it gets hot. If you do run kero in it. put a rag or some canvas over the lower part of the radiator until the lower rad elbow gets a little warm. Running a cold engine on kero will thin the oil out in a short time. There are 3 oil pan valves. After running for a day, Let it sit overnight and then open the middle valve and drain the oil down to that level and refill with fresh oil.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
