Farmall Tractors Discussion Board
Re: Farmall Fast-Hitch
Posted by Roger on March 26, 1999 at 21:58:56:
In Reply to: Farmall Fast-Hitch posted by Chuck on March 26, 1999 at 19:36:18:
We had a 350 with a fast hitch in the 60's. I thought it worked great. The drawbar on it was real handy as you could adjust heighth. I believe the hitches for the 450 and 560 should be the same. the same implements will hook up to all but the smallest tractors. The implements are easy to hook up and unhook, providing the surface is somewhat level. You willneed more than one hydraulic spool if you want to ooperate anything but the hitch. They had a loth of different implements: plows, mowers, cultivators, discs, platforms to carry things, blades, et.
Post a Followup
: Re: Re: Farmall Fast-Hitch
