Farmall Tractors Discussion Board
Re: Water in gas
Posted by Phil Auten on March 29, 1999 at 17:57:06:
In Reply to: Water in gas posted by Fred Patrick on March 28, 1999 at 19:56:46:
Fred,
Orson has the right idea. If you can't find any
"Gasohol", get a pint of "Solox" at the paint
store. This added to a full tank of gas will
absorb whatever water is left in the tank and the
engine will burn it out. Be sure the carb is
clean first, and put in an in line fuel filter
because whatever varnish is in the tank, sediment
bowl, fuel line and carb will be dissolved and can
peel off in chunks and clog the needle valve in
the carb. The fuel filter will take care of this
if you clean the carb first.
Good luck and keep the tank full,
Phil
Post a Followup
: Re: Re: Water in gas
