Farmall Tractors Discussion Board
Re: rivets for farmall regular wheels
Posted by Farmall Gray on March 29, 1999 at 19:06:38:
In Reply to: rivets for farmall regular wheels posted by Phil on March 29, 1999 at 17:02:55:
You need a tool called a "rivet set". It is
basically a large punch with a concaved end.
As large as the rivets are, you will probably
have to heat them with a torch before you "set"
them.
Post a Followup
: Re: Re: rivets for farmall regular wheels
