Farmall Tractors Discussion Board
Re: FARMALL F 30
Posted by Farmall Gray on March 29, 1999 at 20:14:23:
In Reply to: FARMALL F 30 posted by DARRELL LOGEMAN on March 26, 1999 at 21:29:32:
I have a 39 F-30 with demountable front rims, but
the wheels have 5 egg shaped holes in them. These
were commonly seen on late F-20s also. I have never seen any like you describe. They could be
aftermarket wheels. I saw an F-30 at an auction
that had demountable rear rims with solid centers.
They had a name on them but I can't remember what
it was. On mine, the lugs are not the same as an H or M, but the ones from an H or M will work-they just look different. Even if the wheels aren't factory, I would consider using them because they were probably put on when the tractor was fairly new. Plus, they will make your tractor unique. If they aren't factory,
then your tractor probably came with steel wheels.
In 37 the only wheels that were probably available from the factory for rubber tires were round spokes.
Post a Followup
: Re: Re: FARMALL F 30
