Re: Farmall 706 rear wheel adjustment- still having problems
Posted by scotc on March 17, 2009 at 15:26:00 from (12.171.163.27):
In Reply to: Farmall 706 rear wheel adjustment- still having problems posted by Tod in Ohio on March 17, 2009 at 15:13:26:
You have two types of wheels, on one there are 4 bolts to loosen. On the other there is one or two bolts that pull a wedge into either side of your wheel center, and once that bolt is loose your wedges need to be driven out their respective side of the center. Try turning the wheel a little and drop the tractor, turn, drop. That's how Grandpa got the ones on our 1566 loose.
