Farmall Tractors Discussion Board
Re: Re: Even more Farmall M questions
Posted by Gregory Travis on March 31, 1999 at 10:36:47:
In Reply to: Re: Even more Farmall M questions posted by The Red, John Fritz on March 31, 1999 at 09:53:02:
>Q#5 Go to the YT front page and you will see Parts and Manuals section. Very thorough and competitively priced. <
Ooops, my mistake. I should have said that I HAVE
gone to the YT manual section and it IS thorough. So thorough, in fact, that I don't know what manuals to buy! There are some "farmall" entries for "G&D" - I assume that's "Gas and Diesel" - are these the ones I need? There are other Farmall entries as well. I just want to make sure I order the right stuff!
Ok, I forgot Q4, so here it is:
Q4: I assume there's another hydraulic pump located inside the clutch housing. There is a capped-off pipe elbow joint coming out the side of the housing and some kind of filler cap coming out the top. There is NO "christmas tree" derrick, just a cap. Under the cap seems to be a whole lot of steel wool. I assume this is the hyd. fill. and the pipe elbow is hyd. fluid OUT. Is there a hydraulic fluid return?
Extra bonus Q6:
My M has a road gear. I can feel the clutch slip when staring from a standing stop in the road gear - especially when starting with a load or going up a hill. I assume this isn't normal (or is it?). How much of a bear is it to replace the clutch disk in a stock M? The manual makes it look pretty easy.
Thanks again,
greg
Post a Followup
: Re: Re: Re: Even more Farmall M questions
