Farmall Tractors Discussion Board
Re: Re: Re: Super A quits after a few minutes. HELP.
Posted by Curt Cooke on April 02, 1999 at 05:18:52:
In Reply to: Re: Re: Super A quits after a few minutes. HELP. posted by Skip on April 01, 1999 at 18:57:02:
With the fuel left on, remove the drain plug from the carb. That's a verticle plug that takes a 7/16 wrench, not to be confused with the plug over the main jet. You'll get an initial burst of fuel as the float bowl empties, then you should get a small stream. If you get drips instead you have an obstruction of fuel. This is a quick test of the fuel supply. Also, have you or anybody else recently replaced the gasket between the two halves of the carb. If so, you could have a different problem.
Post a Followup
: Re: Re: Re: Re: Super A quits after a few minutes. HELP.
