Farmall Tractors Discussion Board
Re: Re: Wide Front on C or H or M?
Posted by Phil Auten on April 03, 1999 at 11:26:24:
In Reply to: Re: Wide Front on C or H or M? posted by Neil on April 02, 1999 at 17:57:15:
Bo,
All can be fitted with wide fronts. Costs run from $500 up to nearly $1000.
Where are you in Tx.? Reply offline.
Phil
in Central Tx. near Waco
Post a Followup
: Re: Re: Re: Wide Front on C or H or M?
