Farmall Tractors Discussion Board
Update on Stuck, Cracked Sleeve
Posted by TMAC on April 03, 1999 at 18:51:40:
After reading your suggestions, I tried to heat up the F30 sleeve with a propane torch and then as I tried to pull the sleeve out as I cooled it down with ice and rock salt. It wouldn't budge. I decided to trash the block because of a crack on top of the block. So, now I am looking for a block and sleeve. Thanks for your suggestions.
Post a Followup
: Re: Update on Stuck, Cracked Sleeve
