Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: 51 Farmall H update.
Posted by Milan D. Radakovic on April 04, 1999 at 16:11:18:
In Reply to: Re: Re: Re: Re: Re: 51 Farmall H update. posted by Oil Tester? on April 03, 1999 at 17:24:18:
I talked to the guys in the shop, the test strips I was thinking of is for checking for acid in the anti-freeze. It's just a normal PH Test Strip. They collect the oil in a tube (about the size of a 35mm film container) and ship it to a lab, the lab tests for concentrations of various metals to indicate bearing and ring wear. Sorry for the mix-up. Your friend is probably using something different.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: 51 Farmall H update.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
