Farmall Tractors Discussion Board
Re: Farmall F series
Posted by John F. on April 05, 1999 at 09:36:58:
In Reply to: Farmall F series posted by Brandon Dickerson on April 05, 1999 at 06:57:57:
If it's a tricycle tractor and the s/n starts
with an "F" it's either an f-12 or f14. The f-12
steering shaft runs parallel to the hood, the f-14
is about 6 - 8 inches higher at the steering
wheel end. If it's a small wide front tractor
with a flat head 4 cylinder, its a cub.
The s/n tag for the F series is on the back of
the engine, the cub tag is on the right hand
side of the front steering/radiator casting.
Post a Followup
: Re: Re: Farmall F series
