Re: Model H charging system
Posted by gene bender on March 08, 2009 at 15:44:03 from (67.55.227.228):
In Reply to: Model H charging system posted by Stumpy on March 08, 2009 at 15:03:17:
No domt put batt volts on the field. Do you have batt volts on the bat terminal of the cut-out Thats the first place to check. Then you can polarize the gen by touching a wire from the batt terminal to the ARM post on the gen. Make sure you dont touch the field. Then start the tracroe if it doesent chow charge then ground the field that shlould make it charge. There are more things to check but do these first.
