Farmall Tractors Discussion Board
Re: CLUTCH IS STICKIN AND NOT DISENGAGING
Posted by Hoosier on April 06, 1999 at 11:02:04:
In Reply to: CLUTCH IS STICKIN AND NOT DISENGAGING posted by JJ DOG on April 05, 1999 at 20:11:10:
I'd try the clutch adjustment & also grease the throwout bearing. There's a plate on the underside of the clutch housing, held on with 2 9/16 bolts. You'll see the grease fitting up in there. Good luck.
Post a Followup
: Re: Re: CLUTCH IS STICKIN AND NOT DISENGAGING
