Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: MD Low fuel pressure
Posted by Ike on April 06, 1999 at 11:26:52:
In Reply to: Re: Re: Re: Re: MD Low fuel pressure posted by Ronnie on April 04, 1999 at 21:09:42:
Ronnie thanks for your advice. My water trap had the wrong gasket. It was cork, my MD needs the rubber type. My IH dealer had 7 in stock, and said he had never sold one. After putting it on it stopped the mixing. He also had a bleeder in stock, one of mine has been rounded off at the top. I would like to install a Super M hyd pump so I can have a live lift. I've been told you can use old pump as a resevor have you ever had any experence with doing that? If you have how do you control it? Again thanks for your help!
Post a Followup
: Re: Re: Re: Re: Re: Re: MD Low fuel pressure
