Farmall Tractors Discussion Board
Re: Re: Farmall-200/12-volt conversion
Posted by gary belote on April 06, 1999 at 14:40:39:
In Reply to: Re: Farmall-200/12-volt conversion posted by Daniel on March 28, 1999 at 18:44:14:
why 12 volt? put an 8 volt battery in, take your voltage regulator to a repair shop and have it set to charge 8 volts. you dont have to change lights or put in reduction to your points. will make it spin! hope this helps.
gary
Post a Followup
: Re: Re: Re: Farmall-200/12-volt conversion
